Mercruiser 350 Horizon MPI LOSS OF POWER
Status
Not open for further replies.
jg5343
Motor is brand new in 2003, Bravo drive, 23 pitch prop. <br /><br />Had the boat out twice last week on the bay and all way great. Took it to the lake Sat and it now seems as if it is running at about 3/4 throttle. My hole shot is crap. Takes 30 second to get on plane and once on plane I have lost about 3-500 RPMs. Used to run at 48-5000 now its around 4600 WOT with about a 5 mph loss as well. <br /><br />I have replaced the fuel filters, put gas treament in and ran 93 octane through it. Helped slightly, but no significant difference. I checked the linkage for the throttle and it has not slipped. Checked the prop for line/fouling. Nothing. Plugs new last year. <br /><br />Motor response is great, sounds good, nothing at all unusual except the loss in torque/RPMs/speed. I am still able to use the boat, and can cruise at normal speeds after I let it work itself up to being on plane. This motor has been babied and there are no visual signs of wear. Any clue what could all of the sudden be causing this problem? BTW, same gas was in it through out, until the problem happened, then I put the treament in with 93 octane. It ran awesome on the same gas it ran crappy on. Thanks for the help.
bigbrownbuku
Master Chief Petty Officer
Re: Mercruiser 350 Horizon MPI LOSS OF POWER
start with getting the codes read. so much relies on my other senses with efi.
jg5343
At the shop right now getting coded. Anyone wanna ponder a guess? Thanks
Don S
Guessing is a waste of time and money. Troubleshooting is the method used for diagnosing EFI problems. Guessing is expensive.
jg5343
So the guy tells me he can't find the diagnostic connector. WTF! Is there a special connector for this engine that no one knows about? He had a hand full, none of which would fit any of the plugs coming out of my engine. Again, its a 2003 Mercruiser 350 Horizon MPI with Bravo I outdrive. Thanks again
Don S
The connector is located on the port forward section of the intake manifold and is uusually marked with either DLC or Data Link Connector on the harness just behind the plug.<br />I'm kind of guessing on yours, since Merc doesn't go by year in anything, all done by engine serial number.<br />I would be very concerned about your mechanics diagnostic skills if he can't even find the DLC.<br />The Merc service manual shows where it's located.
newport dave
Got to agree with Don. I would be very concerned about him not being able to identify the DLC. Any other shops close by?<br /><br />Dave
jg5343
As soon as I called to check progress on the boat and found out he couldn't find it, I was on my way to get my boat. The only reason I chose him was because he was not backed up for 3 weeks and all I wanted were the codes. Now I am waiting at the authorized dealer anyway. Go figure. Don is right, I have already had issues with the serial number ID vs year/model. Thanks for the info guys.
Don S
You don't usually get too backed up when you don't know what you're doing.<br /><br />Codes are only a part of the process, but with an MPI, if you MUST have a service manual to even think about doing any systimatic troubleshooting.
Status
