1989 thompson will not shift into reverse
thompson 89
HELP WANTED! I HAVE A 1989 THOMPSON I CAN MANUALLY PUT IT IN REVERSE BUT I CAN NOT SEEM TO GET IT TO SHIFT INTO REVERSE. THE CABLE ARE GOOD.
Fishermark
Re: 1989 thompson will not shift into reverse
What engine, outdrive, etc?
thompson 89
mec crusier engine 4.3 leader v6 alpha 1 outdrive
Haut Medoc
How do you know the cable is good?<br />Just because it moves does not make it good...<br />If you can shift it into gear manually (drive off I assume), then you need to replace the cable...<br />If it is a new cable, it is adjusted wrong.....JK
Fishermark
Don S can give a link to the Merc manual, but here is a starting point for you to check the adjustment:<br /> Shift cable adjustment
