bayliner trim tab wiring diagram
pilotkeith2000
I have concoured the steering fork problem (Thanks to all) and really want to start on the cosmetics.... but I have an issue with the trim tabs. Hit the buttens and nothin!! I have power to the switches in and out but nothin. there is + power to the switches in the center pole. when the switches are depressed all poles to the switches go hot. all wires go + hot when depressed. I have purchased a service manual but nothing there on trim tabs Any body got a wiring diagram ???
rodbolt
Re: bayliner trim tab wiring diagram
as bayliner does not make tabs we need to know who made the switch and the HPU or if the tabs are lenco electric ones.<br /> wire colors to the switch are always good as well
I/O WALDO
Open ground at pump?(bennett)
Don S
Below is a link to the Bennett troubleshooting page. You probably have the boat leveler system, and while they look different they have nearly identical wiring so the troubleshooting method works for both.<br /><br /> http://www.bennetttrimtabs.com/trouble.htm
pilotkeith2000
thanks again. will start probing wires.& I will get the name on the hpu. will check the ground also
pilotkeith2000
Thanks agian for the help. Checked for a ground ...and nothin.. found the ground wire disconnected. Switches and pump work goood but I think I may need to bleed the system. i opened both lines when removing the pump (thats when I found the Ground wire disconnected) and when tha tabs are going down now any resistence will stop them. can take two fingers and hold the tabs from going down. How do you bleed these or is something else wrong ???
Don S
Just run em up and down a few times. They are self bleeding.
pilotkeith2000
thanks Don. Will do that. Will let ya know how the maiden voyage goes. Waiting on a new outdrive,( old one has to much salt water cancer) should be here tomorrow, then will install new steering fork busings and put her back together. thanks again for all the help.
Jeff Mitchell
It was working fine and then it just stopped. I'm not sure if the wires that were disconnected were supposed to be connected or not. Do you know how tight the top needs be down on the pump in order for it to work?
bruceb58
This thread is a year old.
Start a new thread.
