Engine spins but boat loses thrust
Stinger2
Boat has been sitting for 3 years, first trip out, motor runs great, but just as it is about to get on plane, engine free revs like it is neutral but no power getting to the prop. I suspect engine coupler, but pulled outdrive, shined light in there, splines look good. any ideas? Its an 86 CC Stinger with Alpha one and 383 stroker
I/O WALDO
Re: Engine spins but boat loses thrust
When a coupler spins,unless the splines R dry or the drive is WAY outta line,there is usually no spline damage to the coupler.The splined piece in the coupler spins against the rubber bushing outside of it.When a coupler spins,under load like yours,U can smell burning rubber in the engine box.Could bee your prop bushing spinning!
Mischief Managed
You likely spun the hub in tthe prop. There's typically a rubber hub in there that is designed to give rather than let the prop or shaft get wrecked upon contact with something solid. An old dried out hub combined with a lot of engine torque would could spin pretty easily. Any prop shop can re-hub the thing for ya.<br /><br />Otherwise, the prop is ventilating, perhaps on exhaust gas. Is it a vented prop?
crazy charlie
Time to either get the prop hub reconditioned or get a new prop.
Stinger2
I hope you guys are right that is the prop...I don't recall smelling any burning rubber and I did have the engine hatch open while I was running it. I don't feel like removing the engine to replace a coupler. Slapping on a new prop would be a lot easier.
KRS
Banned
If the hub is spun, then your impeller isn't spinning, which means you aren't circulating water, which means overheat (if you are raw water cooled).<br /><br />What was your temperature gauge reading?<br /><br />Easy to check on the muffs, see if water is coming out of the exhaust while it's running, but don't burn up your motor.<br /><br />By the way... exact same thing happened to me. Turned out the engine was torque rolling because the mounts were loose/broken and had bad wood. And mine is only one year newer than yours :)
bruceb58
I think KRS meant if your coupler has spun you can overheat.
Stinger2
Took the prop to my prop guy, he was able to turn the hub with a breaker bar, hub is indeed shot!!! I was about to yank the motor to replace the coupler, you guys just saved me a bunch of time and money!!! Thanks guys.
