I have a 1978 260 hp 350 mercruiser the rear motor mounts have been replace with the new style. You sent me the picture of mounts and it explained about the shim kit and the fact that you may or may not need the shims. I have tried it with the shim and without. The tool goes in to the spline but no further I tried moving the front of the motor up and down no luck. Also it had a new coupling last year. It seems to be hitting the top of the spline and i have the shims in could it possibly need two shims. Any ideas you might have thank you
