Mercruiser grease fitting zerc
crazy charlie
A grease fitting is turning out to be a tough part to track down.No marine stores stock them.I have to assume an automotive will not be stainless.Does anyone know the specifics on a merc grease fitting ,size ,what its made of etc., ??
Dunaruna
Re: Mercruiser grease fitting zerc
I don't know specifically what an automotive fitting is made of, but I've never seen one rusty!
crazy charlie
Wow,this is Twilight Zoneish.The guy sitting across from me in my office just said those exact words.And I mean word for word!!!
Charlie, You could use a standars automotove one and leave a film of grease on it. If you run in fresh water it will certainly not be an issue. If you run in salt water, make the coating a bit heavier, and you will likely not have an issue.
michael-lagrange
crazy: try your local industrial bearing dealer,<br />they deal with all kinds of fittings, water related or not.<br /> hope it helps- go fishing.
Alumarine
"I don't know specifically what an automotive fitting is made of, but I've never seen one rusty!"<br /><br />Then you've never looked under my truck! (we use salt on the roads in winter)<br /><br />I've used the automotive zercs on my freshwater boat with no problems.
Zerts used on Merc.s are 1 of 2 sizes of threads.........Same as Everything Else, but the Metrics......<br /><br />The Small 1s are 1/4"X28 threads.......<br /><br />The Large 1s are 1/8" Pipe thread.......<br /><br />And,..... I'm Extremely Doubtful that even Merc.'s are SSteel.......
tommays
Type 303 Stainless Steel— 10,000 maximum psi<br /><br />Brass— 10,000 maximum psi<br /><br />Right on page 2036 of CAT 112 mcmaster carr :) 1.64 each<br /><br /><br />tommays
Hmmmmmm......<br /><br />NAPA was $.59 for 1/8"pipe size...... Steel,... Didn't look for a rating.......<br /><br />Just restocked My Zert Kit yesterday......... :D
