Colin Ambler
- Apr 30, 2006
- 8
My tilt has failed. Mid trip, i pulled the outdrive up because of some low water. I floated away to deeper water and tried to put the outdrive back down with no luck...I had to get towed in. The switch seemed to be failing in the past week or two, it would take a decent amount of flickering the switch for the outdrive to go down. I replaced the switch, and everything seemed to be working better. (Not the case later in the day) When i flick the switch now, the drive stays up, but i can hear something clicking towards the rear of hte engine. The trim switch on the throttle still works. Any ideas of my problem? <br /><br />Also, what are the results of starting the engine with the trim up?
