1993 4.3 OMC cobra <br /><br />Was trying to troubleshoot a problem and possibly found another...<br /><br />The engine vibrates badly (boat shakes)at idle and under 1500 RPM - both in the water and on the muffs. Idle is approx 600 RPM. Once over 1500, boat runs great and the vibration isnt there, or at least I dont feel it. Just replaced distributor, plugs, wires, fuel filter and still the vibration. <br /><br />I pulled the outdrive to inspect the gimbal and ujoints - both were in good shape and greased. I then pulled the drive and ran the motor to make sure that the drive wasnt the problem (I used an old water house directly into the bell housing). Vibration is still there, so it cant be the drive. Could it be the engine coupler? <br /><br />Another potential problem, as the engine was warming up, I noticed the port side exhaust manifold was very hot to the touch and the other was cool. I immediatley turned off the engine and temp never got above 100.<br />Not sure if this is normal when on muffs, or was the hose in the bell housing causing the problem?(I had good flow from hose) Perhaps my two problems are related?<br /><br />Thanks for any advice...
