Volvo reverse lock
cm5408
I am having an intermittent problem with my reverse lock on my out drive. I first put her in the water, the drive will not lock down. After about a half an hour, the drive will lock. I am starting to think that the springs are starting to become weak. Where can I find replacement springs for a 285 outdrive? Are there any other items in this setup that can cause this?
Don S
Re: Volvo reverse lock
It's not usually the springs, but the paws that catch the cross pin when they get rounded over a little they will not hold. Note I said usually, could also be the adjustment, or the springs. Just be sure to check those paws.<br />Any Volvo Penta dealer can get you the parts.
