fendersfender
Thread starter- Joined
- Mar 23, 2005
- 317
'85 searay twin omc 3.8L v6's w/ 800 series stringer drives.....starboard engine misses like heck....have changed plugs, rotors, caps, fuel filters, engine ran good at first start, but after idling up the river it began to miss...i pulled plugs out and all are carbon fouled, i put another set of plugs in her and checked timing and leaned out carb by 1 full turn on each idle mixture screw, (4 barrel quadrajet), but engine ran better when idle mixture screws were turned out, richer?? I am assuming that in is leaner and out is richer? correct? carbs were rebuilt last summer and boat ran good all year. I think i will set carb mixture screws exactly as other engine, and take her out and run the p### out of her,,,,,and the chokes are working as they should...no excessive fuel is spilling into carb while at idle...i'm stumped, any ideas???
