Use sealant on carburetor gasket?
koobek
Am I supposed to use a gasket sealer (Perfect Seal?) on the gasket and mating surfaces when re-attaching the carburetor to the manifold on my Mercruiser 3.0 engine?<br /><br />Thank you,<br />Barrett
Alumarine
Re: Use sealant on carburetor gasket?
Just out of curiosity, why never on carb gaskets?
Scaaty
marc c, theres no need. The seal is fine, as the carb sucks air through that big hole on top,and it will not need to look elsewhere
Conrad, Do you have the gasket? I recently rebuilt my carb, a 2brl Rochester on top of a 4.3 GM V6 and I could tell by what I removed that the gasket was thick, when I got the new gasket it was a good 1/4 inch thick. No sealent needed and dont substitute auto gasket for marine. Donwon
Alumarine
Oh, so that's what the big hole is for.<br /><br />That makes sense - thanks scaaty
rob935
no just make sure you have the correct NEW gasket ,
