Money pit 3.0L OMC?
Just bought 1987 Bayliner with OMC 3.0L. Thanks to your site, I know it is GM. Has not been on water for 4-5 years. Previous owner said that he heard engine knock last time it was ran. Have not taken pan off. <br />Reason for posting: What items do I need to check on the outdrive to see if I just bought a real nice trailer with some fiberglass garbage on it?<br />Thanks
Silvertip
Re: Money pit 3.0L OMC?
Drain it and see if any water and/or metal filings come out! Hopefully nice clean lub will exit. If not. You've learned that B-O-A-T stands for Break Out Another Thousand. (Sorry to steal that line from someone else but I love it!). Hopefully you paid considerably less one would normally pay for this boat since you apparently have no idea what you are saddled with.
Limited-Time
Yep, like stated above:Boat = A hole in the water into which you dump money. With that Obsolete Marine Corp out drive hung on the back maybe. If it’s just the engine your in luck. E-Z to come by and work on.
cobra 3.0
Don't knock OMC. It's a great drive that is still serviced by many. It's a much easier to work on and stronger built drive than the Merc Alpha 1. It's just that some Merc guys on here love to bash OMC's. Ask a Merc guy how he changes an impeller. Yikes! What a job compared to a Cobra!<br /><br /> Mine's a 1986 3.0 Cobra and works just fine. I have no trouble at all finding parts for it. (There are tons of these drives out there.)<br /><br />As for your engine, it's no different than any other GM 3.0! If you have a knock and you know nothing about engines, find a bud that does and have him look at it.
THE BEEF
Thank's Cobra!<br />I have a 1981 800 stringer. I love it. runs smooth and gets up and goes. Do the maintenance!<br />Beef :p
beezee28
Master Chief Petty Officer
Pop-pop, welcome to iboats. You are on your way to know your boat better in this forum. Ask away.
KaGee
Any boat stored that long with a black anchor hung on it will be an equal opportunity money sucker. <br />Just check the threads.
marinemech1
no kagee he said cobra not "black anchor"<br />the beef: remove drive clean carb change points connect motor to fresh fuel see if it starts<br />or take to a good mechanic for opinion<br />decide what 2 do from there
KaGee
Originally posted by marinemech1:<br /> no kagee he said cobra not "black anchor"<br />
I know what he's got, and I know what I said.<br />Maybe this will help... any boat stored 4-5 years, even with a Mercruiser drive, will suck up your money. <br /><br />It's not the drive that's the real issue, it's the time in storage and all the things that could possibly need serviced after sitting that long.<br /><br />All the derogatory things that get said about OMC drives, there is a reason why Mercs are often referred to as "Black Anchors".
