Green Gear Fluid in Blidge - lower Gear Mercruiser Alpha One
coveredup
Re: Green Gear Fluid in Blidge - lower Gear Mercruiser Alpha One
Thanks --- but its on a trailer --- but I just bet water is coming in there --- <br /><br />I was too stupid to look in there while out -- last weekend --- <br /><br />Everything seemed to be going so well -- until I took out the Blige plug and that water came out -- and of course I thought the Gear Fluid was leaking from the reservoir --- <br /><br />I just wonder how much water was in the Blige -- should I be looking at getting a Auto Blige pump ? <br /><br />sure seems like a good idea --- now
Haut Medoc
An auto bilge pump is never a bad idea ;) :) ...JK
NoWorries
Originally posted by Haut Medoc:<br /> An auto bilge pump is never a bad idea ;) :) ...JK
But, eliminating all possible ways for water entering your boat is an even better idea!!!
coveredup
Was doing a little research on the Gear Fuild Tube from the engine --- and do not see how the fluid gets to the lower unit --- <br /><br />I am looking at the drawings on sterndrive.info and don't see it -- does the rubber tube from the engine Gear fluid reservoir connect to the Bell housing -- and then another hose take it to the lower unit ? <br /><br />Just thought I'd get a little educated before taking the boat in to have the drive pulled -- but just dont see the parts for this reservoir system on the drawings -- maybe they are not there -- <br /><br />Really would like to do this myself -- BUT -- not yet
Don S
Here is a link to the Mercruiser service manual.<br />Lots of pictures and information.<br /><br /> http://www.boatfix.com/merc/Servmanl/14/14cover.pdf <br /><br />Basically, the hose goes to the transom shield to a fitting and quick disconnect. On the drive side of that fitting is a short hose to the bellhousing. Then there is another quick disconnect between the drive and the bellhousing.
coveredup
Wanted to let you know it was the Yoke Seal in the upper -- Gear lube was filling the bellows and going back into the bilge -- cost about $700 to get a new seal, yoke, and one x bearing. <br /><br />The bellows looked good - almost new so didnt do that part -- they indicated that would be another wave of cost -- <br /><br />In the process I think I found another Dealer/repair place which might have lower cost than this one -- will try it next time --<br /><br /> also got the top of the Carb pulled as the float needed to be reset ( had a mid-range problem ) -- total $1000 -- -- wheew --
