Velvet Drive Transmission Noise
ross_larter
Hi All,<br /><br />I have a Ford Indmar 351W v8 with a Velvet Drive Transmission (direct drive), ever since the boat shop did a service which included changing the tranny oil the engine has made a kind of rattle noise when out of gear? It used to be very quite!!<br />It seems to be comming from the velvet drive, any ideas what would cause this.<br /><br />Cheers<br />ross
Dunaruna
Re: Velvet Drive Transmission Noise
The type of oil they used maybe............<br /><br />Velvet drives will rattle slightly when the engine is run out of water. Is that what you mean?
waterone1@aol.com
Every Velvet Drive boat I have owned has had a slight rattle at idle. As soon as you raise the rpms slightly (with the boat in the water) the rattle should stop. How smooth the engine idle's will have a big impact on how loud or noticeable the rattle is.
tommays
The coupling bolted to the flywheel is metal with springs that dampen the shock of gear changes.<br /><br />Its louder than a rubber one like a sterndrive and we replaced ours when it failed from old age.<br /><br />The springs started failing <br /><br /><br />tommays
ross_larter
The engine does not seem to be as smooth as when we put it away for the winter, it the springs are failing, what happens when the fail? are they hard to replace? I not bad with a spanner.<br /><br />cheers<br />ross
tommays
Its a plate on the flywheel if they did it the same as the Correct Craft FORD/VELVET drive setup.<br /><br />IF its bad its a sealed unit KIND of like a car clutch it just has to be replaced.<br /><br />The hard part is getting to it to check it so i world rule everything else out FIRST !<br /><br />tommays
ross_larter
Our boat is the same setup as the nautique(correct craft).<br />There is a little dip stick that goes into the velvet drive, but ours has no line on it for full or empty do you know how far the oil should be up the dip stick.<br /><br />cheers<br />ross
ross_larter
Found the noise, it was not coming from the drive after all, but the front pully, the shop put a new belt on it?? After a bit of grease and running for 1 hour it went.<br /><br />thanks for the help<br /><br />cheers<br />ross
