goblehipcom
- Oct 13, 2007
- 5
Re: B3 Corrosion
I know I'm resurrecting an old thread...but the quote above mentions a year when the corrosion problem was corrected. I'm trying to decide being a 2001 with B3's or a 2000 with VPs. My first choice is the 2001 with B3's because it is slightly better equipped in terms of electronics and has a beautiful blue hull. However, the corrosion issues make me nervous.
Did they make changes on or before 2001 to better address corrosion?
Thanks for any info,
-Brian
Those drives were prone to that type of corrosion.Personally,I would avoid them and go for a later year when it was corrected....ddboater--it really does not matter how good or bad a stainless prop is--if you nick it..it will rust,hi or low quality.
-Brian
