Cracked Exhaust Manifolds, Block?
a91civic
1986 Regal Sebring, 4.3l v6 Mercruiser<br /><br />I apparently didn't run enough coolant through the motor, because the exhaust Manifolds are cracked. and leaking water when running. (from numerous places)<br /><br />One of the freeze plugs on the block popped out.<br /><br />Now, when I changed the oil it was milky and some water came out before the oil did.<br /><br />My question is if the exhaust mani's are cracked would that allow water to seep into the block? or is it time for a new motor? it is a 1986 Regal Sebring...<br /><br />Thanks!
rodbolt
Re: Cracked Exhaust Manifolds, Block?
it can allow just that,<br /> however that motor also likes to crack heads and the water passage down the lifter galley area. I would pressure test the block before buying manifolds to asses how much damage is done and then form a plan of how to correct it. <br /> it sounds like you did not drain the block before adding coolant. it happens. i get 4 or 5 a year.
a91civic
What PSi should I be looking for?
Don S
5 psi would test it if it was good, but if the block is cracked where water goes to the oil pan very quickly, then you won't be able to build up any pressure at all.
The Pressure Test that Rodbolt,+ Don are talking about is more of a Pressurize,+ Listen test......<br /><br />Run the pressure up to 5psi or 10 psi,.... No More than 15psi,..........<br /><br />Then Listen for Leaks,........<br /><br />If that's a Crack,.... You'll Hear it,.... Then all you have to do is Figure Out Where it's leaking......<br /><br />If it Holds pressure,.... It's Fine......<br /><br /><br />BTW,...........<br />This is just 1 More example of WHY, it's Better to store our motors DRY................<br />Air Doesn't Freeze................<br /><br />Antifreeze Storage is a Waste of Time,... Money,....And, Dead Fish................ :(
rodbolt
I disagree with bondo on this. I see to many locked up circulating pumps every spring, while air does not freeze,as the water weeps out of the casting it accelerates corrosion(rust). and water will bleed out of cast iron for months. every spring, especially after a few rare 9*F days, I replace 4 or 5 motors maybe 10 sets of manifold/risers and the odd assortment of seawater pumps and oil coolers as well as saltwater washdown pumps and such. another issue is some of the EFI motors have water cooled vapor seperators that will freeze as well and are hard to drain. <br /> so after doing everything and starting the fogging procedure I shut it down, drain the block, hook up about 5-8 gallons of a product like frost ban 2000 and start it back up. this will refill the block,manifolds ,risers,water passages in various coolers and vapor seperators and most importantly rob the block of rust forming oxygen. plus the AF mix has corrosion inhibitors and it keeps the various seals and such wet.<br /> so while no air itself does not freeze it does not protect either and accelerates rust.<br /> add certain minerals and it rusts rapidly.<br /> I use my gearcase pressue tester to test the block assy's. pump it up to 10-15psi and let it sit, if it holds 30 min or so at whatever pressure I left it at its ok.<br /> to set up the test block off any hoses going to the manifold/risers. remove the seawater inlet hose at the Ttat housing and apply pressure there. if it holds the block assy is water tight, if it does not its time to try to listen for air hissing and then a teardown.
tashasdaddy
listen to these guys. i,m just finishing a rebuild. the valves in # 5 rusted up and froze in place. they will save you a LOT of $.
KaGee
We don't have the salt water issues in the Great Lakes Rod.
