merc smartcraft tools
hudman
can an indivual buy the smartcraft diagnostic tool that plugs into the motor and gives you the hour readout?<br />these are used on the new merc fuel injected in out units...
rodbolt
Re: merc smartcraft tools
as far as I know anyone with 1500 dollars or so can buy it.<br /> Diacom also makes software for a PC that does well. <br /> rinda technoligies makes some scan tools as well.<br />why do you need the diagnostics ?
Don S
Not sure what you are asking about here hudman, Smartcraft is a type of gauge setup installed in the dash. And, yes it does give engine hours. Or there is designated diagostic tools as rodbolt was talking about.<br />However, if you don't have an engine with EFI, then you can't hook it up to anything. Then engine needs to have an ECM. In a previous post, you said you have a carbed, non vortec 350. So it wouldn't have an ECM and you couldn't hook anything to it. <br />But, to answer your question, YES you can buy the stuff if you want it.
hudman
Yes, that is my current setup, but the engine had a dropped valve or some other internal problem. I have just ordered a mercruiser 383 magnum mpi motor complete. what do I need to get engine readout? is this already on the motor, or do I need something else? Ive been told that the new engine will plug up to my existing harness and be a simple swap over. I just want to be able to tell more about what is going on with the new one. thanks for your help, Don in particular,,, your vast knowledge of mercruiser stuff really shows....<br />thanks again. <br />hud
hudman
ok, how much is this SC 1000 and how hard is it to hook up?
Don S
The first thing you need to do start at the link below and figure out exactly what you want. As dave's link shows, there is more than one SC 1000.<br />None of it is hard to install if you can follow the installation and instruction manuals.<br /><br /> http://www.mercurymarine.com/smartcraft <br /><br />This from the smartcraft manual. Do you have the 555 ECM?<br /><br />NOTE: All MerCruiser product equipped with a 555 Controller, ECM, or PCM, are capable<br />of using SmartCraft Instrumentation Systems (SC1000 System Monitor, System<br />Tachometer/Speedometer and SC 5000 System View).
Don S
To access Smartcraft pricing, go to the link below.<br /><br /> http://www.mercurypartsexpress.com/PartsExpress/HomePage/homepage.asp <br /><br />>Accessories<br />>Your zip click Continue<br />>Pick dealer click Continue<br />>Rigging<br />>Instruments<br /><br />There several sections on the Smartcraft, you will need the readout unit wiring, and any senders for other than engine.
