1978 175 Evinrude-New guy here
Christian95
Hey all, first off I should say that I am totally new to this forum and boating in general. I bought my bass boat a couple years ago and have had some trouble starting it but after I replaced the starter last year, it started but was still sort of difficult to start. I have followed the procedure pretty closely but I figured maybe someone could tell me something that might help me. I went to start her up for the first time this season and she turned over but would not fire up. I tried the choke but still the only thing it would do was turn over and then sort of clunk and the starter would kick out but the engine won't fire up. So I guess my real question is, why does it clunk and the starter kicks out but not fire up? Sorry if this is a no brainer but like I said, I am totally new to boats! Thanks in advance!
Christian95
First I squeeze the primer bulb to make sure it is difficult to squeeze (which it usually is most of the time) then I pull the start lever up and turn the key to on and push it in. I hear a click and then I turn the key until the engine turns over several times and then clunks and the starter kicks out. Then I turn the key without pushing it in and generally after a few seconds it starts. Recently, it won't start even after the clunk noise.
Christian95
I had my compression checked last year and it was fine. I don't remember the numbers but a reputable mechanic was there with me and checked all of those things. I am mainly curious about why it clunks and the starter kicks out. Is that normal? It has done it since I bought it and has started many times when I turn the key after hearing it.
flyingscott
Could be a bad starter, bad bearing, bad gear could be a lot of things. What did your mechanic say when you told him about it.
emdsapmgr
Jump start the starter direct with a set of automotive jumper cables to a known strong battery. If it turns over normally, the starter is ok. Then check the start solenoid and the key switch. The contacts inside the start solenoid do get burned with age and burned contacts won't transfer enough current to crank the starter.
interalian
I've had starter kickout like that when the motor fires and briefly overcomes the speed of the starter which pushes the Bendix down. I've found more priming helped.
Take the starter apart for inspection.--------Do not run out and buy a new one.--------These starters are elegantly easy to work on.-----Easy to inspect and install new brushes.-------Use a digital meter to check ohms from shaft to the commutater.
Bosunsmate
Thats wrong as well. You only push the key in while you are turning the key to activate the starter. That way the fuel is sprayed in while the engine turns. The way you are doing it means the engine loses its prime.
So try it the correct way and see how you get on.
Bosunsmate
If that doesnt work id also try pulling out all the sparkplugs, grounding the leads and then spinning the motor over with the starter under no compression scenario and checking if it can do that smoothly otherwise you will need to find the source of that noise.
By the way a clunk can happen if you have the wrong lead going to the wrong sparkplug which is a mishap which happens commonly enough
rob1973
I had a 90 hp with same problem. Took to a reputable mechanic. Turns out all was wrong was jelled up carbs. He rebuilt the carbs and all was fine.
Christian95
Alright everyone I appreciate all the replies! Sorry I haven't been on in a few days, but with work it's been hard to get out there. I have run into an issue with my starter so I haven't had much luck with anything else. My starter that is only a year old will spin strong for maybe a second or two and then just die out and buzz. If I try to turn it it'll just click and not move. If I let it sit for a minute it'll spin again and then die again. I took the starter off and one of the brushes was burned so I resurfaced it (still plenty of brush) and cleaned everything off and stuck it back on the engine. Now when I turn the key it'll spin strong for a little longer but still die out. The battery is brand new and charged and I've gone through the connections which seem fine. My next step is probably taking a meter to the solenoid and if that checks out alright then I'm not sure what would cause the starter to spin strong then die. Any ideas?
As per post # 9 ---What was the reading when you used the digital ohmeter ?--Was this new starter an aftermarket or factory BOSCH ?
Christian95
Readings from the shaft to the commutator on each on is 4.36. I am not sure what it is supposed to be at but they are all matched. It is an aftermarket from BG electrical.
From the commutator to the shaft should read infinity.----You have a defective starter according to your readings.
Christian95
I've ordered a new starter. Thanks for the help! I'll let everyone know when I get it in.
Christian95
My starter is set to come in today and as I was out there checking over everything for the day, I noticed a oil and fuel sitting in the 3rd (bottom) carb intake area. If I rotate the flywheel by hand I can hear the pressure bubbling the mixture and can clearly see it when I look into the bottom intake port. Doesn't seem normal to me but thought I'd get your guys advice! Thanks again!
Christian95
Got starter on and works great! One thing I realized is that my ignition says push in for full choke, but when I do that it had a really hard time starting. Then I noticed a little lever that says choke and when I flip that over it starts up with no problem. So I'm a little confused on that but I can't complain cause it starts no problem now!
