capthook
Thread starter- Joined
- Oct 10, 2005
- 154
I have a Mercruiser 1973 3.0 140 H.P. With the pre alpha out drive I belive. Just to give a little history of my ownership of the boat. I bought this boat from a good friend of mine right at the end of the season this year. It needed the gear shifter adjusted and that was it, he just rebuilt the carb and put on a new water pump in the outdrive. I adjusted the shifter as per my manual. Worked great. Ran the boat a couple of weeks before it got cold here in Illinois. Ran great once all the bad gas was ran completly out. When I went to do my winterizing I drained everything fogged the carb and plug holes and changed the oil and filter. I then went to drain the outdrive gear lube and found milk. So I thought that I would just pull the whole drive unit for the winter and reseal the unit. Well to my surprise the seals in this unit were almost all pretty bad. And the water pump seals were all cracked and burnt up. The shaft that runs down through the pump had been rubing on the metel ring that was once the seal. Now the shaft has a little grove wore into it. I think that I can put a small weld on it and then buff it out smooth so I am not to worried about it. But what I am worried about is why all these seal went bad in the pump so soon. I never ran this boat without muffs on it. I did find a lot of mud in the manully water drain passage area in the lower unit that I had to ream out with a screw driver and high pressure air. So my question is what should I look for with the water pump problem and should I rebuild the whole unit or just reseal it and go.
