1987 omc 3.0 starts cutting out at 2800 rpm's
starcar331
i have a 1987 omc 3.0 has everything new from filter to spark plugs, cap and rotor, electronic ignition, coil. but it cuts out and acts like a spark plug or wire hit and miss it had the same problem before all the new parts were put in with one thing differant it does run a little better with the electronic ignition system but still cuts out! anyone have any ideas on how to fix this problem? would appriciate any help.<br />Ron
Don S
Re: 1987 omc 3.0 starts cutting out at 2800 rpm's
Take it for a test run, with a friend. When under way, disconnect the ESA module. Make the run and see how it works. Hook it back up before trying to put it back into neutral.
starcar331
i had tried that but it still does the same thing! i was thinking about the carb adjustment but don't know what the settings are, i appriciate the input<br />Ron C
Don S
Are you saying this is an occasional miss? An example would be running along at 3500 rpm and occasionsally there is a quick miss, or is the engine just not going over 2800 and sputtering?<br />Tere are no external adjustments on the carb for high rpms other than adjusting the throttle cable to make sure the throttle plates are full open.
starcar331
no, as soon as it gets to 2800 rpm's it starts cuting out all the time! have you ever experianced a vehicle with a bad spark plug wire bouncing around it will hit and miss constantly off and on but at differant intervals it will cut out and for just a second it will run smooth then cut out again!
starcar331
on the carb. base there are 2 gas mixture screws if i knew how much the turns were that might help<br />i don't know if it's running to lean or not
Don S
Those mixture screws are for the idle circuit only and have nothing to do with your problem.<br />Have you done a compression test, and run a vacuum test on the engine to see if they are ok?<br />That would be the first step.<br /><br /> http://www.boatfix.com/merc/Bullet/97/97_25.pdf
starcar331
no, thats one thing i have not checked i will check them out today. thanks will let you know what happens!<br />Ron C
starcar331
just wnet out to the boat and didn't find any vaccum lines at all and what i thought was an esa is aperantly the ignition module on the back side of the throtle linkage plate on the side of the engine, it has cable shift!
Don S
Item #71 is the ESA module. The ESA is used with cable shift, all it does is stops ignition to half the cylinders when you are coming out of gear.<br /><br />
starcar331
i will check the compression to see how it is on each cylinder, i use to have a garage and worked on cars for 30 some years, became disabled 6 years ago but still have a lot of my tools the setup on these boats are a bit differant from what i am use to, so the help is greatly appriciated!<br />Ron C
starcar331
i printed out the diagrahm, i think this will help! thanks.
starcar331
there is one other thing, will this module also cause it to be hard taking it out of gear?
Don S
Absolutely..........
starcar331
thank you very much, that was the answer to my entire problem! hope you have a great holliday season<br />Ron C
