Steering alignment
LuckyPenny
I have noticed after replacing my engine that the lower unit turns more to starboard than to port. How can ajust this? I do not remember doing too much to the steering controls other than disconnect the control arm, and it was reattached exactly as I removed it (a single bolt)
Don S
Re: Steering alignment
Originally posted by Luckypenny:<br /> I have noticed after replacing my engine that the lower unit turns more to starboard than to port. How can ajust this? I do not remember doing too much to the steering controls other than disconnect the control arm, and it was reattached exactly as I removed it (a single bolt)
<br /><br />With all my abilities, I should be able to figure out if he has a Mercruiser, OMC, Volvo, Yamaha or what ever else is out there. <br />Surly this thing can tell me if it's hydraulic or cable steering and if hydraulic if it is a balanced cylinder or not.<br />Maybe even what model and year the thing is.<br /><br />Hmmmmmmmm, I think I'm getting something here. Canoe????, Nah, that can't be. Stupid ball, just never works any more.............
LuckyPenny
it is a mercruiser. it is a cable with power steering.
Don S
Alpha, Bravo, Year ????? Engine?<br /><br />Why is it always so hard to get information out of some of you guys. Is it some top secret or something?
LuckyPenny
it is a 1977 mercruiser 5.7L (250HP) with an Alfa
Don S
My guess is you have an 898 engine and drive. (It was not called an Alpha in 77, it's an 898 if it's still the original drive.)<br />Anyway, mounted on the inner transom shield is an aluminum tube that the steering cable attaches to. It's probably adjusted to far one way or the other. loosen the 2 big jam nuts on the tube and adjust it till the steering is equal both directions.
