you were right don s
gord 495
i posted a question a few days ago don about an exhaust sound comming from my aq 125 a, you said check # 4 exhaust port for corrosion, and you were right. also gave me advice on setting drell up on the points, and that helped alot. thanks alot don..good advice. gord
QC
Re: you were right don s
Originally posted by Dunaruna:<br /> The master strikes again.
Yup. The man is a) awesome and b) amazingly dedicated to helping
Don S
Master??? Awesome???? Amazingly dedicated???? give me a break guys. It's nothing more than seeing it a bunch of times over the years while working on all kinds of marine engines. <br />AKA--- Experience.
gord 495
now, can you tell me how to fix it without spending a pile of cash ?
gord 495
jb weld any good ? it's a very small opening
gord 495
and can you tell me why # 4 always gets hit like that ?
Don S
Nope------ It takes a new or good used head. No epoxy stuff will hold up to the exhaust.<br /><br /><br />Ok, what is "sensai"...... I don't get out much???<br /><br />Did he curse me????
QC
Sensai is a Japanese word for leader or expert I think. I know you think it is simple, but you take the time to read and post. That is note worthy in itself. Take the compliment, modesty is OK, but you do help people!!
Mile-High Mariner
Don:<br /><br />I posted a query re: valve guide seals earlier this evening. As you are an experienced pro, can you direct me to a good source? Motor is a 1992 Mercruiser 3.0L (S/N: 0D805131). I'm pulling the valve cover to replace valve stem seals and check valve action on Cyl. #2 (low compression), and I noticed on p.3A-15 of the Mercruiser manual a reference to the guide seals - do these even need to be replaced? I'm trying to rule out the valve train in my low compression issue, so I'm going to check all possible causes of sticky valves. Thanks for your time - you've previously made valuable contributions to my ongoing efforts to get my engine back into top running condition.
Dunaruna
A sensai is the master of a dojo, a karate school.<br /><br />It is a term of respect, if the pupils don't refer to the boss as 'sensai', they get smacked upside their head.
Don S
Ahhhh Soooooo, Thanks Aldo
