350 SBC Vortec Conversion
FreeBeeTony
I am contemplating converting my '92 350 Magnum to a Vortec by replacing the heads and manidold.<br />Looks like a simple conversion but I have a couple of questions:<br /><br />1) Can I use the same rocker arms and pushrods?<br /><br />2) Will my accessories bolt on to the heads? (P/S, Heat Exchanger brackets, etc..)<br /><br />Can't think of anything else at the moment....
bomar76
Re: 350 SBC Vortec Conversion
It still won't be a Vortec...you will need to install the Vortec roller cam and lifters.<br />A 92 block should have the holes for the guides.
FreeBeeTony
It already has roller lifters and cam.<br /><br />I think it was replaced with a long block in '01.<br /><br />Another question: how nuch HP will I gain?
1) I Believe So,......<br /><br />2) Ayuh,..... Absolutely,.........<br /><br />3) About what Dennis says about converting Your heads to Big Valves.......... 25/35hp....<br />(when you have your heads checked,.. Ask the Shop How Much for those Big valves)<br /><br />It's the Efficiency of the Vortecs,......<br /><br />The trick is to get the Quench right at .040s......<br />Better than 9/1 compression ratios on Regular Pump Gas......<br /><br />I'm also Still baffled,.... I don't see any Real Reason for your Issues,... Yet........ :( <br /><br />Good Luck Tony..........<br /><br />Oh,.. BTW,... I ran the #s on your heads at mortec.com,+ they're Standard(light weight) production heads from the dates for your motor........
Scaaty
Just a sugestion Tony...why don't you google a SBC/350Chevy forum. Those car nuts will have your answers in seconds.....
FreeBeeTony
Thanks guys.........<br /><br />Bondo......in order to get the quench right you need to change pistons (I think)......don't want to get into that..... :) <br /><br />I already started searching for a pair of heads.....looks like I can get a pair of heads for ~$200, machine shop says ~300 for reconditioning......+ another ~250 to open the valves.......<br /><br />If I go this route I will probably leave the stock valves in.........<br /><br />I also have to buy a manifold!<br /><br />I don't want to beef it up too much where I put the drive in danger either.........<br /><br />From what I have seen the vortec engines are rated @ ~300+ HP......if I opened the valves I would probably be at ~325.....would that be dangerous? remember this is in a 24' Grady.......I would like more power to turn a bigger prop and keep the revs down.......don't intend on running past 3500 RPM's......
The Quench is somewhat adjustable with headgasket Thicknesses,.............<br /><br />$200.00 for used light weight castings,......(not the best castings to start with)<br />$300.00 for machine time,........<br />$500.00 equals the price of Brand New bolt'm on,+ Go Vortecs............<br /><br />Check out this search I just did,.. Search......................... <br />About 1/2 way down the page,...$500.00 Brand New,.... Free Shipping.......<br /><br />Robby is Right,......<br />Take a wander over Here <br />And over Here <br />You have to sift thru the Kids,... But there's some Real Good SBC info in these places........
FreeBeeTony
Thanks Bondo.........that is a pretty good deal....wonder if I could find ones with the bigger valves?......... :) <br /><br />Tell me more about the head gasket......do I have to worry about the valve clearance with respect to the piston?<br /><br />I also found a few forums.....gotta regioster to post..........<br /><br />keep in touch!
That's where the Efficiency comes in,........<br />Vortecs with 1.94 valves will flow as good,.. or Better than the heads you have Now,.. With the 2.02 valves.....<br />
Your pistons have the Valve Reliefs,......<br />Shouldn't be any problems,........
FreeBeeTony
I was reading a somewhere and they used 1.6:1 rockers........if I buy the heads in the link you gave me I would need to buy rockers.......should I get 1.6:1? Would I need to worry about valve clearance then?
Buttanic
Not sure but compression ratio could be a problem. I believe vortec engines have dished pistons and small combustion chambers. If you have flat top pistons the compression ratio may be too high with the vortec heads.
FreeBeeTony
That's the kind of thing I am not aware of.......<br /><br />Bondo, is that what you were talking about by adjusting the thickness of the head gasket?
FreeBeeTony
Just got off the phone with a local machine shop / engine builder, they said the compression shouldn't go up more than 0.50. According to the manual, the stock compresion is 9.3:1, so I would be at 9.8:1.........would that be ok? Does this sound right?<br /><br />What would be the problem? Would I then have to run on higher octane fuel? Really don't want to have to buy "high Test"!
Tony,...... Google up Vortec Heads,............<br /><br />You'll be All Weekend digesting the Info......... ;) <br />The 1st hit is a pretty good paper,+ the guy says to Avoid the 906s I have because the Exhaust Valve Seat is alittle restrictive,.. they came off the Truck engine....<br /><br />Your Pistons shouldn't be any problem at All,......<br />I went back,+ looked,.... You have 4 valve reliefs,+ a small centered dish......<br />Your Not going to be running a Tall Cam,.....<br />I don't see Any Valve to Piston Issues..........<br /><br />You need to find out how Deep your pistons are at TDC,... How far Below the Block Deck.....??<br /><br />Go Google,.....
Buttanic
9.8 might be a little on the high side for regular gas. Did they tell you what the combustion chamber volumn is. I just built a 350 with flat top pistons and early 76 cc chamber heads and the compression ratio calculated out to 9.04.<br />I thought the vortecs were about 60 cc's with a larger dish in the piston. I would try to keep the compression ratio close to what vortec Mercruiser or Crusader is. Crusader spec is 9.4 and I believe Mercruiser is the same.
FreeBeeTony
The more I read the more I am considering going for the vortecs........and it looks like I could get a new pair for ~$500........glad you suggested that Bondo......I would have been pi**ed if I paid the same money to have a pair of junkyard ones rebuilt.<br /><br />Are the ones on ebay the right casting #? At the end of the description it calls for both casting #'s.<br /><br />I found a compression calculator online...have to get all the numbers.<br />Looks like the vortec's have a 64cc chamber.<br /><br />What about going to 1.6:1 rockers?<br /><br />Which head gasket should I use?<br /><br />Not getting much response from the hotrodder sites.......
FreeBeeTony
Just used the calculator.......I think I would need a 0.06 compressed head gasket to keep the compression down to ~9.5:1 with the 64cc vortec chamber assuming the piston has about a 4cc dish. I estimated this with the calculator assuming the manual is right that the stock compression is 9.3:1 with a 75cc compression chamber on the existing heads.<br /><br />I am really learning something here...!!!
4.3sunbird
compression will be fine .. not only does actual compression matter but the better burn of the combustion chamber will keep it from detinating<br /><br />Im running 4 valve flattop pistons in my 4.3 with vortech's and not having any problem ..If you did a degree or 2 of timing drop would fix it<br /><br />voortech's have alot of plusses over older gm heads .. well worth the swap<br /><br />I'd say stick with 1.5 ratio rockers so you dont have to worry with coil bind on the valve springs<br />or pushrod clearnce where they pass thru the heads
4.3sunbird
nope completly flat with 4 reliefs <br />sealed power H345ncp ... same part # for 350 or 4.3
