Boomyal
Thread starter- Joined
- Aug 16, 2003
- 12,072
This morning I am going to change the plugs in my resto motor, change the oil, fill with coolant and clean up the tools that are filling the boat....<br /><br />...and then I'm gonna try to START IT!! Whoppee!!<br /><br />I spent most of this week correcting various problems. The original 30 y/o water pump back plate gasket was leaking so I had to drain the motor, tear the whole front end off, incl the heat exchanger, and put on a new gasket.<br /><br />I went to put my exhaust manifolds on and they were hitting the aluminum valve covers that I worked so hard to get a paint up pretty. GRRRRR, I had even added a 1/4" stainless header flange as a spacer to try to get more distance from even the original sheet metal covers. I then ordered a set a Ford Racing aluminum covers, 2nd day air, from Summit and they were even worse. I ended up having to mill down the thick mounting pads on the bottom of my original set of aluminum covers and they finally fit.<br /><br />Then I filled the motor with oil and rammed the dipstick down the tube. When I pulled it back out it was covered with glass bead grit from when I bead blasted the tube. I never thought to blow out the inside of it. So now I have to pump the oil out, remove the tube assemble from the bottom rear oilpan drain hole and flush some oil thru the motor to push any grit out that might have made its way into the bottom of the pan.<br /><br />On the 9th of August I ordered an MSD ignition to power my factory 5.0 litre platinum plugs gapped at .55. Today I just got an email from the seller asking where the money order is. It's been 10 days and he still didn't have it. I had thought it would have been here for this occasion. So I had to go buy a set of standard gap copper core plugs to temporarily replace them.<br /><br />Tomorrow will be the big IF. If the used 4 bbl Holley I bought was not a pig in a poke, she should fire right up. If it does, out I will go onto the Grand Columbia and give her a test run. <br /><br />I have really been racing the clock because there is a Boy Scout Water weekend coming up next weekend and I promised that my boat would be ready.<br /><br />Please all, Keep your fingers crossed.
