I have the same, or so I think, issue as Freebeetony. I ended up replacing my ignition coil with an old one and it made a huge difference. I went from 3200 to 4200 RPM on my 1995 3.0 Merc. I thought that was the issue, so I just bought the entire ignition system new. Prestolite cap, rotor, points, condenser and wires. Guess what happened... I went back to the exact same symptoms. Now I am really baffled?!?!? While out on the water, I fooled with the point gap (dwell) just to experiment and found that it seemed to get better the more gap there was, but maybe I'm full of it. What else could the issue be? It really seems to be happening under load. engine speed is less of an issue. If I bury the throttle out of the hole, the 'bog' will happen. I also concur with Freebeetony that it is not exhaust or carb in my opinion. I've eliminated all of those issues. My question is how much of a factor are plugs? I have NGK BR6FS Plugs installed. The gaps are(.35) and adjusted my timing to 6 deg. Color was a nice darkish tan brown. My suspicion is that the ignition system is having a hard time making a good spark when under load. Is it harder for an ignition system to make a spark under load, or am I again, full of it!? I've been working on this for three months now. I've been following Freebeetony and we have very similar, if not the same, issues. What could be a weak point in the igniton system? Any help would be great.<br />1995 Mercruiser 3.0 with Prestolite distributor and conventional ignition.
