up date 5.7 merc hard hot startind
bolo789
ok guy iam back with some more info on 89 merc 5.7l as i said the engine hard start after a run and shut down, when i first go to the boat it start right away. <br /><br />this is waht i notice today my starboard riser is hot that i caunt keep my hand on it. the port is running cool and nice.<br /><br />on my way to the fishing ground i notice my oil guage slightly falling from 40 to about 15 cutting back on the throttle bring it back up to 35.<br /><br />when i came in i pull the risers and i saw some water in the manifold i took out the plugs and crank the engine and just a small spew out<br /><br />my??? is can a bad manifold cause overheat ??<br /><br />could that be my problem hard starting after a run and sit for a while.<br /><br />also my risers a brand new the manifold are, as is <br /><br />also could there be a bad head gasket . ?? <br /><br />help don and friends i think i am getting close, i will put two new risers
bolo789
Re: up date 5.7 merc hard hot startind
sorry the risers are new the manifolds came with the boat
bolo789
also the reading onb the dash guage is 145 it does goes past 150.<br /><br />but after i cold start, the gusge seems to run up to 145 too quick
bolo789
it does not past 150
Don S
I can't see your manifolds, so can't say for sure, but in my experience - if the risers are bad, so are the manifolds. The only exception is if the manifolds are fresh water cooled and the risers are raw water cooled.
bolo789
thanks don the risers is not even four month old the manifolds dosent look too good kinda cracky at the edges
bolo789
any more infos
