Tow 19' Boat w/Toyota? Your Tow Vehicle?
BarryBob
I currently have a 19' Conroy (Glastron) bowrider with 120hp Mercruiser that I am towing with a 1994 Silverado 4wd XCab that has 192K miles.<br /><br />My wife is bugging me to get something that gets better mileage because we only need the truck to tow the boat about 10 times each year.<br /><br />Any suggestions on an inexpensive tow (less than $5,000)vehicle that gets better mileage?<br /><br />Thanks,<br /><br />BarryBob
rickdb1boat
Re: Tow 19' Boat w/Toyota? Your Tow Vehicle?
What is the weight of your boat?
k5ranger
you can go to NADAGUIDE.COM ang look up your boat mode. this will give you a rough idea of your boats weight. (or you can run your boat across a scale if ones available to you) i would feel that a toyo would be fine as long as you prepare yourself to place helper springs on the rear of the toyo or you will probably have a sagging back end.<br /> i have a 93 jeep grand cherokee laredo with 189k miles. i currently pull my 19' c/c that weighs 1500lbs(according to the manufactures website). the back sags approx. 2". no real problems yet. i will no more after next weekend, i will be pulling the boat to santee cooper which is about 4-5 hours for me.
JB
NOT!!<br /><br />Unless the Toyota you are considering is a Tundra don't even think about it. Helper springs do nothing for your transmission, cooling system, differential or brakes.<br /><br />My guess is that your boat, ready to launch, on the trailer is going to weigh well over 3,500#.<br /><br />Any vehicle that is going to get much better mileage than your Silverado is not going to be safe to tow that much weight.<br /><br />K5Ranger, your boat, after you add an engine, fuel, gear and put it on a trailer will weigh over 2500#. Your Jeep will probably be okay with that, but you may have too much weight on the tongue of the trailer if it makes the vehicle sag. Weigh the rig and find out the tow rating of the Jeep and the weight rating of the hitch.<br /><br />You don't want to find out if your rig is safe from a hospital bed.<br /><br />Good luck. :)
D
DJ
Guest
Keep the truck and buy her a car that gets good fuel economy.<br /><br />You can't have both in one package, and be safe.<br /><br />Any "truck" you get MAY increase your overall fuel economy by a couple mpg. Is that worth it for 10 times per year?
airman
My dad tried that once. Burned the clutch out of that poor truck the very first time he pulled it out of the water. I've got a 19.5' cuddy and I've resigned myself to owning a full sized vehicle as long as I've got the boat. You might consider trading the truck in for an older beast and a nice little car. Leave the beast parked (uninsured even) most of the time and pull it out when you need it. They're great for city driving, too! My old Dodge is door-ding proof and shmucks can "park by feel" against it all day long. I washed it this year, but that was the first time it's been washed since 2001. I might wash it next year, too. It runs good, though.
montanaman
Barrybob, if your're going to get a toyota, get a corolla to drive aroung and leave your chevy alone for towing. If you get a vehicle that gets better gas mileage driving around doesn't mean it will get better mileage towing. IMO, the bigger the tow vehicle the better, safety being the #1 reason, power the 2nd.<br /><br />Sometimes too little power will cause lower fuel mileage because the engine has to work that much harder. <br /><br />I got the same thing, '92 chevy to pull the boat and a corolla to run the kids around. Works great.
fireship1
Hello, Yep agree with the group. I have a 2001 Lincoln Navi for towing. A 1990 Ford Ranger for running around and commuting to work. If I tried to pull my 21' bowrider with the Ranger, I would surely toast my clutch and make my tiny four banger cry! But then again the Navigator forgets the boat is back there when towing! Keep the truck and buy something small and cheap for commuting. Besides gotta save gas money for the boat, don't waste it filling up a big truck for running around. Get a little four banger for the commute! ;)
mattttt25
disagree w/ jb. i tow my 20' cc w/ hardtop with my 2002 toyota tacoma. it's rated for 5000 lbs and does just fine. i take it slow and easy, and have had zero problems.
BillP
A Toyota will tow it (even if over loaded) but how hard it is on the drive train depends on how far and fast you tow. If driving 5 miles at 45mph to the ramp and back is all you do 10 times a year it probably won't be a big deal...if the tongue weight isn't too much. Whether the car will launch/retrieve easily at the ramp is another question.<br /><br />For an inexpensive tow car under $5000 you can find a mint early 90s towncar. V8 & rear wheel drive with rear auto level air suspension. For $1500 you can find a mint 80s model. Low milage Towncars are cheap on the used market and are typically well maintained.
JasonB
I have a relative of your 19' Conroy. I have a Glastron 195 with a V8. Your boat is very similar. The dry weight of the hull on mine is 1400lbs, add 1000lbs for the driveline (your 4cyl would be about 300lbs lighter), 50 for a battery, and I carry 36 gals of fuel at say 300lbs. Now add 100-200lbs for gear, anchor, etc and it adds up quickly. I guesstimate my rig at 3000lbs wet and ready + trailer. My current trailer weight 700lbs for a single axle. That's 3700lbs total. I am mopnung to a tandem axle that probably weight 1000lbs. I tow witha '99 F-150 2wd w/4.6l v8 and brakes on the trailer. I would not want to tow this boat with anything smaller. This boat has a very tall profile and catches wind on the highway. I agree with the others. While a Compact truck may have the rating to pull the weight, your abiolity to control it effectively may be a problem, esp after you put people in the truck.
POINTER94
Bob, <br /><br />Sounds like a dream scenario. A 1994 Silverado won't get you much on the used market and it probably is ideal for the tow job you are looking for. I have a 1994 Ford Bronco (Full Size) which isn't the best tow vehicle (short wheel base), but it has the brakes, suspension, and power to tow my 24 foot cc. And when I want to go to the Home Depot or run around in the woods with the dog, there she is. I love snow storms, she's a snowmobile!<br /><br />I would keep the truck and get an econo-box for the day to day.
MajBach
I need to add my experiences to this discussion. I don't know the weight of Bob's rig as that is an important factor obviously. <br />When we purchases our 17' Sylvan with 90 hp Honda, I was contemplating having to buy a larger vehicle specifically for towing the boat. I hated that idea as I am simply not a fan of trucks or SUVs a part from their utility applications. Even living in the country on a hobby farm where I have to take my own garbage to the dump and where you might think a pick-up is a necessity, I get by on mid-size import and use a trailer. I really don't believe there are significant differences in a car that size to an S-10 or Ranger. Hp is not that much better, you sacrifice ride and comfort as well as cabin space and fuel mileage is in a different ball park. I’m also not sold on these vehicles being any more rugged in the long term either.<br />So, for the first year, we kept our boat in a slip, if and when I had to move it I borrowed a friends pick-up. At that time I had a sports car and would never consider a trailer hitch for it. When it came time to replace it - for the purposes of towing the boat - I hadn't decided yet on a truck or car. The specs on the boat were 950# from the mfg and 350 and some change for the motor. With equipment and fuel I was guesstimating around 1500# I would be hauling. Although it exceeded what the mfg's recommendation on towing on any import car, I knew it was do-able from experience ( I had towed trailers for moving in my college days and eventually my first boat - a 14' with 18 OMC - without problem with an even smaller import car). So I ended up buying a Honda Accord. We got the more powerful engine, ABS and manual transmission.<br />Well, I was wrong about the weight of the boat - by a long shot! At the end of the first season (around the time we got the car but before we had towed with it), I took it over the scales at the local landfill. EVERYTHING was out of the boat, including the seats. It was only the boat and motor, no fuel. It registered 2300 lbs! Add at least 400 lbs. for equipment and another couple hundred for fuel and daily supplies and we're approaching 3000 - the weight of the car.<br />Nevertheless, I tried towing it. There was absolutely no problem. It got going just fine, handled even better. Although I get a lot of 'looks' on the hwy as people passing from behind only see the boat an no tow vehicle - :) . Fuel mileage dropped from 36 to 29 mpg (CDN gallons), but thats still better than a pick-up even without towing a trailer. I do have to pick my ramps carefully as the steep ones will give me problems if I they are gravel, but I do have the advantage of FWD. I have on more than one occasion pulled boats of similar size to my own from the water when the owner could not do it with his full size pick-up because of RWD - but that’s an entirely different debate. To be fair, I have had to have a pick-up pull me from the water twice as well.<br />The car has not showed any sign of complaint either. Yes, on some steep hills, I have to go right down to 2nd gear but I am still passing the 18-wheelers. On really hot days if I have the A/C on, I will see the heat gauge creep up. I travel the speed limit on hyws as any faster requires a noticeable amount of extra peddle pressure. The car has 270,000 kms (170,000 miles) and is only on it's third set of brakes from the mfg. - just recently too. The clutch is only just beginning to show signs of wear. I change the oil every 5000 kms instead of 7500 as recommended as well I change the timing belt at shorter intervals. <br />So pulling the boat is fine, what about stopping? Well, I certainly do need more distance and believe me, I give myself a wide birth always when towing. But it's not as bad as you would expect towing something that weighs as much as the car. As soon as I learned of the boat's weight, I was to make it a priority to get trailer brakes. I knew I had crossed the line from being capable of towing, to towing responsibly. However, somehow time got away from me that first season and I never did it. It didn't seem like such a priority as the car seemed to be fine for the job. <br />Then we had an 'incident' while on our way home one holiday weekend. To make a long story short, a tire AND rim came loose of a trailer traveling the opposite way on the highway and was heading right for us. Our combined speed was no less than 100 mph conservatively and there was less than 200 feet of distance separating us when it happened. Having much experience with motorcycles and advanced driver training in my youth, my reflex was to avoid the oncoming projectile (which was now in the middle of our lane). This emergency maneuver may be a mistake when towing, especially at high speeds and considering the weight of the tow vehicle. But as I said, it was reflex as there was NO time to think. The rim/tire combo hit the driver side headlight and bounced over the car, coming down and caroming off the boat’s port rub rail. It then took out the side view mirror of the van following us to closely before traveling into a corn field. My passenger side tire was already on the loose gravel shoulder adjacent to at least a six foot ditch at the time of impact. The boat was still ‘following’ the hitch from the center of the lane in what was sure to be a violent fish-tail as I became aware of my mistake. The brakes were fully applied –with ABS kicking in – by the time the boat caught up with the car, both wheels on the shoulder. The entire time from point at which I saw the tire leave the trailer to the point where we were fully stopped was certainly no more than 6 – 7 seconds. <br />The arse hole on the tandem trailer didn’t even stop.<br />The car suffered $5800 worth of damage , including ABS and A/C (although the ABS worked for the accident) in addition to the cosmetic damage. The boat was not damaged significantly other than a black mark on the rub rail. The lateral force from my swerving to avoid the tire was enough to put a sideways elbow in the transom saver as well as almost flatten the ‘Y’ that the skeg rests in. The four mounting bolts for the outboard were also bent and the outboard skewed– indicating the inertia involved.<br />We were fine though. I was actually furious and my wife was having a near breakdown, but we were unscathed. <br />Every time I recall the event I realize more and more just how close we really came to a visit from the grim reaper. I am still amazed that I didn’t lose control of the car as well. It must have a lot to do with the balance of the boat as you can easily lift it with two fingers from anywhere along the draw-arm. I never had a fishtail problem with it necessitating having to put more weight to the bow – go figure. As it turns out, swerving is probably what saved us. When the tire/rim came off the trailer, it hit the pavement and bounced. It was on an upward path when it struck us (this should give you an idea of how close we were). Had I hit the brakes, no doubt I would have slowed enough to allow the tire/rim to miss the hood of the car and go right through the center of the windshield. Don’t forget, the tire hit the driver’s side but in the middle of our lane; we were already partly on the shoulder. Guess we were just lucky that day.<br />I have since put inertia brakes on the trailer.<br />Take what you want from this post regarding two vehicles. I won't argue that my car simply wasn't designed for towing, espescilly heavy loads. The extra demand I place on the car and the premature wear to it is my choice. So far, I am convinced the car is capable and it has answered my demands without complaint for 3 years now. On the other hand, there is a the responsibilty of being safe to your passenegers and other drivers. This is why I added the brakes. And I do drive much differently when towing. There are many boat trailer combonations out there where the boat weight far exceeds the tow vehicle's. So basically, I do not have any problems using a mid-size car to pull moderatley heavy boat. <br />Hope you enjoyed the story.
RatFish
mattttt25,<br /><br />Any idea on the total weight you're towing? I have a 2002 Tacoma PreRunner and have never towed anything over 1500lbs. I'm curious about other people's experiences towing with their Toyota Tacomas.
quantumleap
Master Chief Petty Officer
Look at a Jeep Cherokee. Not the Grand, just the cheep jeep. They quit making them in 01, but a 97-01 with the H.O. 4.0 inline six was redesigned and makes a nice tow vehicle. Rated for 5000lbs. and gets decent mpg's without the boat. Good luck.
BarryBob
Thanks to all for the information and entertainment! Keeping the truck seems to make the most sense. I have had classic cars for the summer and was trying to see what the different options were.<br /><br />Being a car freak (and a poor one at that), now I just have to figure out between the two options (keep in mind I live in VT):<br /><br />(1) Drive truck in winter and to tow boat, and buy classic for summer (more mileage on the truck but fun driving for summer)<br /><br />(2) Drive truck to tow boat only and buy a cool car for less than $5,000 to drive all the rest of the time. I'm thinking 87-92 Mustang convertible 5.0 and using it all year round except when the snow is deep - then use truck.<br /><br />Any favorite car choices?<br /><br />Thanks, all<br /><br />BarryBob
mattttt25
ratfish- i've never weighed it, so don't know for sure. my calcs (which change every time i think about it) are as follows:<br /><br />- dry boat w/ hardtop - 2400 lbs<br />- engine - 400 lbs<br />- fuel - 360 lbs<br />- gear (very little when towed) - 100 lbs<br />- trailer - 800 lbs<br /><br />so around 4000 lbs. all my numbers are a little high, so i'm probably a bit less. like i said, my tacoma is rated for 5000. i excelerate very slow, keep the speed down (40 on back roads, 50 on flat highway), and give myself plenty of time for braking. i only tow a handful of times each season (boat slip), but i have never had any problems.
RatFish
mattttt25, <br /><br />Thanks for your input. My Tacoma is also rated at 5000lbs. I'll be towing around 4000lbs this spring. <br /><br />I was interested in your experiences towing with your Tacoma since I have not towed anything over 1500lbs with it. I will be doing mainly local trips (10 miles or less) and few trips to the Jersey Shore (65 to 85 miles). I take it easy towing and it's pretty flat down here in South Jersey, so I'm confident I'll be OK. I installed a limited-slip differential for the ramps.<br /><br />Thanks again.
BoneDigger
I'll add my two cents to the conversation. I'm not sure if you are considering a Tundra or a Tacoma? My Tundra (4 x 2) has a V8 and towing package. Last year I pulled a 4000 lb camper from Texas to SC and back and had absolutely no problems at all. My Tundra is the TRD with heavier duty springs. I now have a 17 ft CC that weighs in at 1300 plus a 90 HP Mercury which I think is around 500 lbs. For less than 2000 lbs the Tundra doesn't even know there's a boat behind it.<br /><br />Now, about fuel... In the best of conditions with my V8 I only get around 19 MPG. Pulling the camper I barely made 9 MPG. I'm not sure what I get with the boat, but it's lower profile and more airodynamic so it's probably somewhere around 12-13 MPG and that's a guess.<br /><br />I agree with the others, unless you absolutely need a new truck, I'd keep the Chevy and buy another car for beating around in. I use my Tundra for hunting, etc. so it made more sense. Plus, my old truck was a Ranger and wouldn't pull anything. If mileage is your only concern go with a diesel. They are made for towing.<br /><br />Todd in TX
raymondmoyer
It's nice to have a boat, trailer,outboard and gear that weigh 600 lb total. I could pull it with a tricycle :D :)
