maphillips3
Thread starter- Joined
- Jun 14, 2005
- 64
OK, I have an 86 Bayliner with 2.3L volvo AQ131A motor. last sunday I was out on the lake and everything was fine. The boat was running great,perfect RPM at WOT and it had been starting right up, not for the things that have gone wrong: I every so often have to used the bilge pump as I have a small leak from a hose in the back of the boat(different problem altogether) about 4 hours into the trip I notice not only water coming out of the bilge, but also some gas. Not a good thing, as I could beging to smell it too. I went about boating thinking everything should be ok, as the boat had been running great. A few minutes later the boat sputterd and stopped ("dieseled"). I pulled off the engine cover to see fuel driping from the bottom of the carb. I waited a minute thinking it was flooded and tried to start it again. it turned over, but still nothing. After coming home I tried to start it again, and basically the same thing,turned over but nothing. Then the battery got weak enough that it would not turn it over, it would just chug, and click. Today I hooked it up to my Jeep while it was running and tryed to jump start it, even with the battery from my jeep it would still click. It would click like this several weeks ago as well but after a couple turns of the key it would start. stupid me, just left well enough alone, and now it is kicking me in the butt. I can not even try to work on the other problems till I can get it to tunr over. Can anyone help me?
