Figured it out !!!!!boat won't do over 3200 RPM
vipzach
The mechanic says everything is right with the motor, timing, spark, gas. It starts up easy, revs great in nutral, under load it won't do any better than 3200 RPM. I have a 14.25R17 SS rapture prop. What else to try?<br />BTW it is a 1991 VIP 17.5' 3.0 with alpha 1 drive.<br />thanks Zach<br /><br />Well it was the wrong gear ratio!!!! He had put in 1:50 not 1:98. Now it gets up and runs 4500 RPM and runs like a champ. Thanks for the replies.
Boomyal
Re: Figured it out !!!!!boat won't do over 3200 RPM
Have you checked that the carburetor linkage is full open at full throttle? Not a Merc expert but that seems like a pretty stiff prop for that motor. I'm running a 15 x 17, with a 1:1.50 ratio, on a 20 ft 5.0 litre. My WOT gave about 4700 rpm with a whole lot more umph behind it.
tommays
a healthy 3.0 should have no problem spining that prop<br /><br />i can run a 14 x 19 on a 19 ft with a 3.0 at 4800 that 2 to 1 ratio makes a big difference<br /><br />it has made RPM in the past ?<br /><br />check timeing for full advance and other basic motor things <br /><br />tommays
jeff13601
I was thinking prop at first but that boat probably came with a 14 x 19. It should turn that 3200 easy. I guess you should do what has been suggested and check the linkage and do a tuneup
vipzach
It has new plugs, rebuilt carb, mechanic said it is advancing fine. I checked the carb linkage and it opening up all the way. I don't know abot what it has done in the past, I have only owned this boat since Dec. It also has new impellar and gimble bearing and the top half of the drive rebuilt.
tommays
there is no other way than to start at the most basic thing<br /><br />do your OWN compression test and work from there you dont really no that the motor is healthy unless you do it your self<br /><br />same thing with the timeing you have used a mech and not solved the problem you have to see that it is really working corectly and not thinking that it is<br /><br /><br />tommays
vipzach
Ralph 123
I remember a case just like this about a year or so ago...
QC
Wow! Just goes to show, can't rule out anything. I bet you're relieved.
vipzach
Very relieved, I finally got to fully enjoy my boat last night. I loved it!<br /> :D :D :D <br />Ralph did the same thing happen to you or just somebody else on here?
Scaaty
Originally posted by vipzach:<br /> Well it was the wrong gear ratio!!!! He had put in 1:50 not 1:98.
Good Lord, thats the LAST thing I would think of!
Ralph 123
Somebody else on here. I almost posted the suggestion but figured you knew what you had... sorry. Wish I had posted it. You can still find it using the search function.
vipzach
I knew what I was supposed to have, and my mechanic/friend swore up and down that there was no way he could have made that mistake. Finally the other night I made him recount the gears....guess what....he was wrong. It is funny now, but not last weekend when I was at the lake.
KaGee
Geee boss, I always did want to werk on one of dem dare outdrive thingys..... :D
