ehenry
Thread starter- Joined
- Jan 6, 2002
- 2,393
All, I need a little wisdom on a big honkin Champion 60 gallon upright air compressor I've been given......The compressor works and is functional. It builds pressure and cuts off at the set point. The only thing I can see about it that need replacing are the pressure gauges. My question is this......can the compressor be laid on its side to be moved if I drain the oil out without damaging anything? Its going to have to be laid down anyway to replace the drain **** in the very bottom of the tank and I was planning on doing that when I moved it. I have a tractor with a FEL and forks. I've got to move it from where its located down a 1/4 mile gravel drive, through my property to my shop. I'm figuring if I already have it laid down on the forks, it cant fall and really damage something.
