New Impeller lube Bravo
Status
Not open for further replies.
QC
I have heard to use vaseline for lubing up new seawater pump impellers (rubber type). Is this correct? Anything else better? Worse?<br /><br />2001 6.2 Bravo 1
QC
Re: New Impeller lube Bravo
Thanks guys. I think I'll go with the soap. I've got that handy and seems like less of a mess than the vaseline.
TilliamWe
Banned
Shop was wrong.
QC, I have seen people ask this before, so I'll ask you, can't you just put the impeller on the shaft and twist it as you are pushing it back together? That is how my 1997 works. No need for lube or anything.
Uraijit
Banned
You don't want to use oil on rubber pieces. It will cause them to swell and break down.
Dish soap works great. That's what I used. Probably could force it in there, but with soap, it just goes right in.
Don S
2005 Post guys
JustJason
if your going to use anything use something water based.
KY works... hehe
TilliamWe
Banned
That's my point, with two hands (even easier if the Mrs. holds the housing) it just turns right in, no "forcing" required. I just wondered if I was missing another point of all this "lube it up" mess?
Uraijit
Banned
Try it. You probably won't question it once you've done it.
No helpers required. Put a light coat of dish soap on the "fins" and you can slide it in there with one arm tied behind your back.
And twice on Sundays!
QC
2005 Post guys
Yeah, and I still haven't decided . . . I've got some KY handy . . . did I really type handy and KY in the same sentence? I'm starting to feel like Peter Griffin. Somebody stop me . . . :eek: :D
TilliamWe
Banned
I'm with Bond-o! This is too funny to stop!
Don S
Since this thread is now headed downhill very quickly,
images
Status
