Stang_Guru
Thread starter- Joined
- Jul 26, 2010
- 8
First post here and would appreciate ANY help you guys can give as im still learning things as i go with this project :lol:
I am fairly well at doing my research into things before giving up, but ive hit a brick wall this time and will try to give all the details i can that may be helpful.
Started a project restoration last year. Bought a used and neglected 1994 Chaparral deckboat( former saltwater boat, now only freshwater lake boat). solid boat, needed some mechanical and cosmetic TLC, but overall, a nice project and what i needed. it had a Mercruiser 305 lx, and alpha one outdrive. after running it twice, realized it was failing, had it checked by my mechanic. cracked block. had a new Rapido Marine 5.7 longblock but into place. heres where im lost. max RPM 3800-4000. gps 33mph. did 38 with the cracked 305 :facepalm: i know there is more life in this engine, so is it the prop?
1994 Chaparral Sunesta 220
3400-3500lbs dry
Mercruiser 5.7 350ci lx
Mercruiser alpha one ( tags say its correct with 1.50r gearing).
New fuel pump, lines serviced.
carb rebuilt.
new ignition.
outdrive fully serviced, new impeller, fluids, and new gimbal bearing.
everything gone through and serviced.
Unknown prop brand. Its stainless steel stamped Turbo 14 1/4 x 17p
This boat is hard to get on plane, takes a few attempts with only me and the wife and less than 50lbs of gear, and half tank of fuel. Engine fires on first crank, smooth as silk running/idleing/revving, no missfires or sputters.
This boat will be used for cruising/fishing 80% of the time but do accasionally like to pull tubes and maybe skis in the future.
you guys have the best boating forums on the planet, would be great to be able to solve this.
3400-3500lbs dry
carb rebuilt.
new ignition.
