C17LoadSmasher
Thread starter- Joined
- Nov 24, 2001
- 152
Hey all, Well it's about that time again, and if anyone remembers I had taken the outdrive off to isolate the noise from the engine/sterndrive on the 3.0L Merc Alpha 1 Gen 2. I also went and changed out the water pump as well. I had found some metal flakes (small, but noticeable)in the lube oil when I drained it, and I put the lower unit and the upper unit back together. Now the fun part - I decided to go have the dealer check out the lower unit (they'll know what they are doing, me - not so much)- currently, the outdrive is still unattached from the transom, I was thinking that I should hook it back up, but if they are going to have to take it back off probably anyways, why waste my time? Any suggestions? Thanks in advance...
