Trailer Glyde-Sliks
flywhaler
has anyone used, had any luck, or know anything about these plastic/silicone strips that go on bunks?
Riggerdave
Re: Trailer Glyde-Sliks
I have teflon strips on the trailer that came with the boat I just bought. They are very slick when wet. When I put the boat back on the trailer (first time) I shot right up to the winch! So I have to say that they seem to work pretty well. My only concern is that they reduce the amount of surface area the hull is supported by when on the trailer. I haven't seen any cracks around them though.<br /><br />Dave
Major Woods
I can push boat off my trailer by myself. Prior to the slicks it took 3 people. Well worth the cost. ;)
blifsey
I looked at them but haven't purchased any. I did hear of 2 potential problems to watch for:<br />1) DO NOT releaser bow strap/rope until you have backed down ramp or boat could slide off onto ramp before you get to the water. Even without slick slides, I keep bow rope connected until I've backed in and cranked motor.<br />2) Watch the screws that hold the sticks on. I heard from one fellow whose screws had backed out just enough to put an ugly gouge in his gel coat.<br /><br />As to question of amount of support for hull, I had same concern. The ones I looked at at BPS recommended 2 strips next to each other for boats over a given size. Can't recall exactly what that size was but I felt I would need 2 for my 17-1/2' fish & ski. Another option is some slick'em spray for your bunks. There's a product called "Liquid Rollers" or some folks use silicon spray (not a "caulk" type product), PAM, or furniture polish.<br /><br />BL...
josepr
I just got them put on my trailer and it worked great.<br />I have a 26.5. I backed it to the water,unhooked it and just barely backed up about another 1/2 foot and stopped. It slid right off.<br />Be extra carefull to unhook ONLY when ready.
daschtick
These were probably the best investment I've made in my boat! Before, I would have to completely submerge my trailer to move the boat on or off, but now I can use the shallowest ramps without any trouble. Also, mine came with a warning label stating to NEVER remove the winch hook until ready to launch. This should be common sense.
chaparral442
my concern is the support on the boat I am going from 4 inches of bunk width to only 2inches if I double the slicks that cannot be good
Gary H NC
I just bought a set from a guy that makes them.
They are the hard white composite strips.They are solid and much better than the hollow type sold at most places like Bass Pro,cabelas,ext.
Also they come in 3 inch wide strips by 1/2 inch thick with good recessed screw holes.
Had them on mine for a week or so now and it makes a huge difference.
You can launch with the trailer much more shallow and it helps to center the boat...
Here is a link to them..
http://cgi.ebay.com/ebaymotors/REPL...ryZ26455QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
rob711
this sounds like another to good to be true products..but so did smart tabs till i got a pair..i have similar proplems with my trailer...i sprayed some silicone spry on yhe bunks and that did the trick..i guess this is a more permanent solution though...and yes smart tabs do help
glastron86
These sound great...but doesn't that work against you when you are loading the boat? Sounds like you would have to have somebody right there ready to hook up the winch, otherwise the boat will slide off?? Or am I missing something? I am redoing my trailer and instead of adding new carpeted bunks, I thought about just buying some of these and putting these on my old bunks. I load and unload the boat alot of times by myself, just put the trailer all the way into the water, but that is not the preferred way.
Expidia
I bought the end style from Cabela's for $12. They hook over the end and are about 10 inches long on the part that lays on the bunk.
On the mounting directions they say "do not use with painted aluminum boats"
Because if a boat is painted they will wear the paint off in the area the boat slides over them.
They also say "do not use with riveted aluminum boats" as the riviets will chew the plastic slides up.
My boat is both painted and riveted so I had Cabelas pick them back up at their cost as their web page did not indicate these warnings.
I would start with the spray on stuff first. You can always add the slides later if you're happy with their slippery effect on your your hull.
I opted to not use anything now, because I trailer a lot and find many tricky situations where the friction helps hold the boat part way onto the trailer.
In shallow launch areas where I can't drive the boat part way up the trailer. I pull the boat half way up with a a rope first and I need the friction to hold the boat until I can hook the winch strap on, especially in the wind.
Too bad too, they looked like a good idea to me. But one can always add on an electric winch too. I'm starting to get jealous each time a boat next to me pushes a button and the boat comes up automatically :cool:
Bigjohn1
These devices do what they say - they make your bunk "slippery so it's easier to load and unload your boat. What many boaters fail to realize is they also reduce the "grip" your bunks have on the boat hull WHILE YOU ARE TRAILERING. If you absolutely must have bunk slicks, it is possible you just might need to back your trailer in deeper during launch and recovery. If you use these devices, you MUST ensure your winch strap, winch safety chain, and transom hold-down straps are present, in good condition, and tight. There have been cases of boats sliding on the trailers as they go down the road due to devices such as these. I am not bashing the product or saying they are patently unsafe, I am saying be prudent when using any devices which is purposely designed to reduce friction.
new_boater
what is the difference then if you use rollers?
they have no friction either
i ask because i will soon redo mine (bunk) and have thought about picking slicks on instead of carpet
Gary H NC
I have used the slicks on 3 trailers now with good results. I do make sure my rear tie downs are tight and i use the 3000 lb ratchet straps on the back,new winch cable and safety chain on the bow..
sjlnys
I have a 23' boat on a aluminum bunk trailer with carpet and I can only launch where there is sufficient water to submerge the trailer 75%. The advantage of the carpets is I always drive the boat on the trailer right up to the winch and it stays there while I go around and hook up the cable and bring it in the last 6 inches or so. I don't know if these slick would help me , particularly when I am by myself loading the boat.
