Bradmph
- Aug 30, 2009
- 24
I think I am having a fuel pump issue with my '77 850 thunderbolt. I can squirt fuel into carbs and the boat starts right up, runs for about 20 seconds and stops. I removed the fuel pump and the filter was clean and the diaphram was ok, though it was a little bit stretched from the pressure put on it by this springed cap that was located against the diaphram. This was centered right in the middle of the diaphram and the cap on the spring was about a 1/2 in. in diameter. I could not locate this spring and cap part in a parts list to rebuild the pump anywhere. Is this part supose to be there or not? This spring is pretty stiff also, though it does not look bad.
I included a picture of the parts in my pump and I also created an image on this picture showing the spring and cap that was found in the pump.
