gschultz05
- Aug 15, 2010
- 24
ok guys here is my problem i have 1986 175hp merc blackmax and the temp alarm sounds off....the solid beep. have had this problem for awhile now and did research after i had virtually replaced entire cooling system did the water pump, impellar, and thermastats, and just did the poppet valve (relief valve) although after i did the poppet the pee came out better and my pressure at the gauge had returned to where it should be and pretty solid before it would jump all over the place. no the problem is i can run the motor all day long at 4200 rpms but as soon as i go over that within moments the temp alarm goes off then i back off the throttle and bring the boat off a plane and the alarm goes off and i can proceed up to 4200 rpm again and run all day at that. what could it be i am getting frustrated with this my next step is to replace the head gaskets cause i have read somewhere that if the gasket could be leaking and that could cause it. i know the temp sending unit is original so could it have a weak spring and activating earlier than it should??????please help
