1977 Johnson 9.9hp starter assembly question
maryk
I have this kicker motor with an electric starter. When the motor is in neutral there is a cam on the gear shift lever that activates a pushbutton switch that allows the starter to engage. The cam no longer presses down on the pushbutton hard enough to activate the switch and the motor doesn't start. I can press it down manually and get the electric starter to work. My question is what is this pushbutton part called? Is it the shorting switch?
Sixmark
Master Chief Petty Officer
Re: 1977 Johnson 9.9hp starter assembly question
edit
tashasdaddy
shorting switch is a push button on the cowl, to shut the motor off. you are talking about the neutral safety switch.
here is the proper part. 0386457 SWITCH ASSY.,Neut start. ELECTRIC START MODELS 1 $59.97 USD
it may be adjustable, so you can get the existing to work.
