150 v6 looper 1996 carb/fuel hose connection
Status
Not open for further replies.
T Smack
Hi everyone, I'm almost complete with my rebuild but I am now stuck at the fuel connection. I got this motor and the fuel all unplug already when i got it so I don't really know where all the fuel hose connection go. I got all the connection right from the VRO pump to the fuel hose and the primer where it split into each side of the carb.
But the rest I am clueless, so I was wondering if any body have a photo or a page of a repair manual that hose where all the fuel hose suppose to be connected to?
Thanks in advance.
chadpcb
Re: 150 v6 looper 1996 carb/fuel hose connection
Each bank of carbs should have it own Fuel Manifold with one connection for the main line in.
chadpcb
Here is a link to a manual.
http://search.ebscohost.com/
user: marshall
pass: public
Main Categories >
Marine/Boat Motors >
EVINRUDE/JOHNSON >
OUTBOARD 85-300 HP 2-STROKE, 1995-2002(INCLUDES JET DRIVE MODELS>
FUEL SYSTEM>
MINLON CARBURETORS (V4 & V6 LOOP CHARGED MODELS) Page 2
T Smack
Wow thank you so much for the access. Hopefully it show everything I need to see.
T Smack
The manual doesn't really say where the end of the balance hose are suppose to connect to. It show that it's connected to the balance tube that goes on each intake manifold but doesn't show the other end of the hose. Any idea?
I will take some pictures and post it up tomorrow. I think starboard side the balance house is connected to the bottom of the crankcase cover and the port side is connected to the air silence? Am I correct on that?
OK, Here are the connections from my '98 Johnny 150HPV6 OEM Service manual page 2-52. It is a 60* looper..
Port balance tube connects to bottom of Air Silencer. Starboard balance tube to lower main bearing. BTW the air output from the vapor pump connects to the lower main bearing as well.
T Smack
Thanks for the balance tube parts, next question is u said the one of the vapor out go down to the other lower main bearing.
Can you look at the picture and tell where they go. I can guess that A(lower main bearing) would connect to D on the Vapor. Then C would go to to E?? And does any thing connect to F or Where does B plug into?
T Smack
Got it running thanks everyone for all your help.
Dinosau
Hello TSmack
​I know this is an old post , but I just ran into the same issue with a loose hose
where do the hose A connect to at the lower end ?
I read some info about lower main bearing , is there a nipple down there
how do I get to it ?
thanks in advance
GA_Boater
Hello TSmack
thanks in advance
Dinosau
You know it's a thread that's 6 years old, yet you post anyway asking a guy who last visited 6 years ago. :facepalm: You know how to start a new thread - Do it!
Closed!
Status
