bob johnson
Thread starter- Joined
- Feb 25, 2009
- 4,306
1995 115 hp ocean runner.
starter bendix will not kick out to engage the flywheel, the motor spins when you turn the key though....
the starter has never given me trouble in the 1.5 years i have had the motor...not one hitch... ran the boat last saturday.
during this past week i decided to check the high speed jets, and i took the motor cover off and the air box and worked on the carbs from the front...over three different nights. i made a tool to allow me to access the jets in the lower carbs with out taking the lower motor cover off.
I put the air box back on a few times during the week.... there are plenty of wires working their way in bwtween the carbs in the front of the engine.
Is it coincidence that part of the starter just stopped working right after i worked on the carbs...or have I pinched a wire?
I did find a purple wire dissconnected from its bullet connector in front.. looks like it went to the primer anyway...
I am wondering if there is a wire tha could be pinched or dislodged that runs the bendix portion of the starter.
I have a spare starter selinoid on the bench , but before i try that, Id like to try what ever else i could that doesnt involved as much dissasembly
PS there SEEMS to be enough battery juice... the tilt-trim motor runs fine!!!
but I really dont know the batteries charge level at the moment( at work now)
hope to hear from someone...thanks
bob
bob
