freeisforme
- Mar 23, 2009
- 184
Today a buddy that's been tinkering with an older Sportcraft, about a 1966 or so model, 15 1/2" long, closed bow hull, came over for me to mount up a used 60hp twin he bought. The boat has a 20" transom but because of the stepped hull at the rear, I chose to mount it a hole higher than normal. The boat has a HP recommendation plate on the transom stating that the recommended horsepower is 65 to 130hp.
I hung the motor, hooked up the controls, hooked up the antique cable steering, and fired it up. The motor sounded good so down to the water we go.
Figuring that the boat with two big guys and 12 gallons of gas and two batteries would weight upwards of 1600 lbs or so, I was only expecting it to do about 25 mph or so. To my surprise it felt much faster. So back to the dock I go, grabbed my GPS, and gave it a check.
The GPS read 43.7 MPH at about 3/4 throttle. The prop pitch is too low, so it will over rev easy, but even so, at 5,500 RPM it's over 40 mph? The boat hull is heavy, without the motor, two of us couldn't lift the bow or stern on the trailer, and it's listed at something like 1210 lbs in the owners manual.
It jumps up on plane fast, and takes right off, far better than it did with it's original motor, which was a 90hp Mercury inline 6. With the old motor, it was a dog, slow to get out of the hole, hard to keep on plane, and terrible on fuel. I wasn't expecting the smaller motor to run this well.
I ran it for about 15 or so miles, it barely moved the fuel level in the tank. The old Merc would have swallowed up nearly 1/4 tank or so.
I've got no clue as to where the motor came from or what it really is other than the model and hood match and say it's a 60hp 1986 20" shaft length motor. It sounds louder than my 55hp that I run on my boat, it's raspier and quicker to accelerate. It sounds like a big dirt bike more than an outboard.
It's got a new water pump kit, supposedly has a rebuilt lower unit, has 145 psi compression, and a rebuilt carb. The head has been off and the all gaskets look new. Is there something that could have been done to this to gain a little extra HP? It idles great, is a little rough through the lower mid range, and hums nicely at higher RPM.
I'm wondering if a higher pitch prop will gain me speed or lose speed and acceleration? Since it's not mine, I don't want to leave it where the motor can be over revved so easy. It would easily rev well over 6,000 RPM the way it is. It doesn't seem to gain much over 5,500 RPM in speed, not as much as it gains in speed between 4,800 and 5,200 RPM.
The boat handles great, the motor runs at a normal temp, no overheating, and it didn't blow out the prop at any point. All of which were concerns since the anti cavitation plate sits about 2" above the bottom of the transom, which is already stepped about 3" compared to the rest of the bottom of the hull.
I've run many OMC 50 to 60hp twins over the years, and never had one run this fast on this size boat. Even on my old aluminum boat, a 16' hull, I never got much over 34 mph on the GPS. What has me thinking is that this may still have more speed if I play with the prop diameter and pitch.
Does anyone have anything similar out there with some real numbers to compare to? I'm sort of wandering here what I did right or what I did wrong?
