Are the starter parts good or bad?
bisonfan
Hello all:
I pulled the starter of my 115 johnson to check it over. The problem I am having is the starter only spins the motor about 2-3 times before it acts like a dead battery. Battery, ignition switch have been verified as good. Solenoid checked. Volts at starter when cranking are 11.11 when cable jumped from battery to starter standing alone and not on powerhead.
I am wondering if experienced eye can tell by looking at the pictures where my problem may lie.
When I opened it up, I found a ton of black dust in the bottom cup where the brushes sit. A loose screw on a (what appears) to be a ground wire to one of the brushes. The brushes are worn but don't appear to be excesively worn for a 1990 model. The wire binding (armeture?) is covered with a plastic like substance (is this normal?)
Any comments would be greatly appreciated!
I can add more in the morning if needed as my camera battery died while taking pictures.
jimdd810
Re: Are the starter parts good or bad?
Time for a new starter. Could have that one rebuilt for cheeper.
Sixmark
Master Chief Petty Officer
Judging by the pictures alone, that starter has seen it's last day. Combine that with the fact that you only have 11.11 volts when cranking.
Parts of the armature look like they have been cooked over time. Being that the armature is in such poor shape, I wouldn't even recommend a rebuild being that you need a decent armature to rebuild around.
bisonfan
Thanks for the responses. I will check into if it is possible for it to be rebuilt or just get a new one...
F_R
Thet armature looks like it is burned up. Sure is black anyway. It also looks like it was dragging on the fields. Are the field magnets broken?
As they say in the electrical trade, the smoke got out and it won't work any more.
