Charging - solar & alternator
carlh
Hi,
Am looking at installing three 250AH batteries and two 140W solar panels to charge them via a MPPT charge controller.
Question is, when engine is running I want to use the engine alternator to charge instead of solar. Can it be done and how?
Carl
bruceb58
Re: Charging - solar & alternator
No need to disconnect. They can all be connected at the same time. Done all the time on motor homes. Since the MPPT constantly monitors the battery voltage, it will see the high voltage caused by the alternator and believe the batteries do not need any more current from the solar.
Check your manual on your charge controller to be sure though.
carlh
Super - that makes the whole idea so much simpler, I will double check before I buy the controller.
