My Osco risers and manifolds are getting way too hot. The engine's temp is normal and I checked and replaced the impellor and I'm still having problems. A friend of mine said Osco's run warmer than other brands. I'm not sure I believe that.
There's a clear hose beside the black inlet hose (not metal?) showing in pic 1.....
I assume the carb and fuel pump is also marine and not automotive!
What kind of flame arrestor and throttle bracket are they? I am lookin for them for a carb change. D Mc
I have the same Osco set up on both my motor and never had a problem. I agree with what keelhauled said about the timing and the second part about the raw water. I heard of a similar situation in which the block stayed cool but all the heat was soaked up in the exhaust.This is a stab on the dark, but Don S might be on to something with the HEI distributor. Is your timing retarding or too retarded causing heat build up in the exhaust?
I'm thinking you are getting more than adequate raw water to your engine to keep your block temp normal but the heat is being carried out by the water which is piping hot by the time it reaches the riser?
I'm probably way off but I wanted to have a guess too![]()
