slow but steady
Thread starter- Joined
- Dec 15, 2009
- 5
Hello to everyone out there in boating land. I have been reading these threads for some time now and have found many answers to questions I've had. This is my first time asking for help but I cant seem to find the information that I now need. I have a 1982 Evinrude 50 hp outboard (e50belcnr). I bought it about a year ago with a 14ft Mckee. It ran OK but didn't have much power but a fuel pump rebuild solved that. Not long after that I lost a ground and traced it out to the the large red connector on the port side of the engine. It had broken right at the pin terminal inside the connector. After that I got to looking at the other wires and connections, and several of them didn't look so good, so, wanting a dependable motor I replaced all terminals and connection with new terminals w/ heat shrink. Also replaced all wires that looked questionable and wrapped them in anti-chafe conduit. Other work that has been done recently for different reasons are, both carbs have been rebuilt, both coils ,power pack, spark plugs, thermostat, water pump, head gasket have been replaced. Some were bad some were for precaution. Well that's pretty much the history. My question is, will this engine run if the battery goes dead. I ask that because yesterday while going along about half throttle, the engine made a loud noise (like a broke rod) and cut off. After finding that I could turn the flywheel all around and no internal noise I tried to start it and the battery was dead. Got it towed home, charged the battery and checked the rectifier and stater with the ohms meter. They both checked good. Started the engine and battery was charging. Did the wiggle test to check for bad connections. None found. So anyway, would a weak battery cause the engine to cut off?
Sorry for the long novel but I wanted to give as much information as I could.
Thanks in advance,
Joe
Thanks in advance,
Joe
