Re: 1957 evinrude fastwin 18 hp
First problem, idle and high speed jst adjustments. ( note this must be done on the lake in the boat)First set the high speed jet to 1 1/2 turns open from lightly seated, second do the same with the low speed jet. With the motor warmed up to oppereating speed, run the motor up to WOT, now adjust the high speed jet, turning it in CW 1/8 of a turn at a time, wait a few seconds after moving it, for the motor to react. Keep this up untill the motor stumbles. Once it stumbles turn the jet out CCW 1/16th of a turn till it runs at the highest rpm. Now turn the jet back CW 1/8 of a turn, that should get it right. Now at an idle speed, do the same to the low speed jet, turn it in till the motor stalls, or almost stalls. Then turn it out till the motr reaches max rpm, then turn back in 1/8 turn.
As for the tillarm turning? do you mean the throtle on the handle or the whole motor tiller and all move?
