I've been reading relevant posts here, ordered manuals and been to library gathering alot of material, am finally gonna ask for help.
I bought a Maxum 1700 with an '89 Force outboard. This boat and outboard is pristine. I know the couple I bought it from and bought the boat because I knew the guy has always been great at maintenance on his toys and he sold it to me cheep. The problem is the boat had been in his garage for almost 5 years sitting. I know I have to do the carbs and just about everything else but I wanted to hear it run for a minute and fired it up (on muffs) after putting an impeller in it (the old one was intact but had been chewed a little). I cranked it and cranked it and gave up. Later I went to put the boat away for the day and decided to throttle it all the way up and crank it one more time. It fired, then started running. I can't say it really ran except for maybe 15 seconds. I freaked and shut it down because I wanted to see the water coming out the back and nobody was there to look for me. All the warnings from impeller posts here did that to me!
Since that time I have not gotten the motor to start again. I was reading a long no-start post on here from last Spring and hoped it would provide me with the answer only to see it end with the guy finding out his compression was bad. Mine is good? 3 cylinders, 130-135-140.I did have to buy a replacement starter. The replacement was a dud with the mandrell? gear flying up to the flywheel and the top nut unscrewing up and almost coming off the starter. It grinded into the flywheel making a squeel as it came to a halt. I rebuilt the original starter enough to make it work while I await a replacement new starter for my replacement starter. So I have the original 1989 starter on the motor but it works for now but no start. New spark plugs and each lite my tester between the plug and wire. This tester does lite but the lite seems faint. I can barely see it. I'm so afraid I'm going to need a CD module or something really expensive. I traced the wiring for the ignition, key, battery, starter, relay but not the stator or CDmodule side of the motor since I hope I'm getting enough spark. I had drained the boat's tank also so I worried about the gas and old lines and bought a portable tank and new gas line that I ran to the fuel pump (I checked the filter of the pump, looks clean). When the motor started, it was gas from the built-in tank with fresh gas.
I could really use some direction since the possibilities of what is wrong could be anything. I don't want to throw parts at this thing. I'm grateful the compression seems good but I have to buy a battery charger now although the battery is new. Should I just accept that I have to rebuild the carbs and clean the reeds before it will fire again and hope for the best? I've never done it but I believe I can. If so, I'll do that and then come back to you as I go. Sorry this is so long but I could really use your recommendations here. I'm beat and going around in circles.
