Re: need help up here in boston
Hi,
Do you mean when you open the choke plate by hand the engine idles OK, right?
Then, when you release the choke plate the engine dies, Correct?
If this is the case, you have a bad choke. I don't know if you have a electric or vacuum actuated choke. I just replaced my Mercarb 2BBL electric choke this season. It's very easy.
For a quick fix so you can get out on the water: You can safety wire the choke plate open. Just make sure you warm up the engine on the trailer at home with muffs on before you head for the launch. Cary a can of starter fluid to help ensure any cold starting issues on the water. You see that choke closing when the engine is warm is causing a lack of air flow into the carb. At sea level an engine burns Approx. 1500 gallons of air to one gallon of gas. No air, no go. That's why no internal combustion engines for NASA in space! LOL
Only do this latter method if you feel confident with the boat.
Johnny.
