89 Force Choke issue
ropaint
My chokes occasionaly work but usually just clicks and the choke twitches a little but doesn't close the carbs. Is this a part that frequently go bad or is this more likely a bad wire?
Thanks for any advise.
Rick
Unforcefull Force
Re: 89 Force Choke issue
Are you able to move the choke freely by hand, connected to the solenoid and disconnected from the solenoid?
-Mark
Lwapo
Fyi - i'm no expert.
I remember reading that solenoids VERY rarely die. However, the grounds are known to get corroded or go bad.
I would try removing the solenoid and trying it with jumpers. My guess is the ground or a wire is bad.
1983rinker
try a new Circuit Breaker, 6-12V DC, 20A.
Unforcefull Force
I wanted to make sure that everything can be freely moved by hand...process of elimination.
-Mark
1983rinker
when i put a new breaker on mine works every time now. mine was doing what yours dose.
jerryjerry05
WD-40 or spray lube on the choke solenoid.Spray and have someone hit the switch.Then keep doing it up.They get gummed up.
Use your fingers get in and move it.J
