jmontois340
- Apr 25, 2009
- 8
Hey guys, I have a J150GTLCUR 1987 and I just replaced the water pump. I'm fairly certain I did this correctly. The outboard has been sitting for 5 years so i didn't expect a smooth rebuild but here's the problem i'm having...
I turned the motor over for the first time today on muffs. after priming and letting the starter do it's work for a few seconds (10-20) the motor would start and run on idle for about 20 seconds then i shut it down when i noticed there was no water coming out of the pee hole. I checked the hose and the pee hold itself for blockages and there aren't any.I ran it 2 or 3 more times and still no water from the telltale.
I read on a few threads here about the tstats possibly being seized so i decided to give them a look. I took them out and the area of around the head that you can see when you take the stats out looked bone dry which told me that no water was even getting to them. When they were out I boiled them and they are working fine.
I planned on taking the lower unit off
mad: what a pain) tomorrow to check the water pump but Im not really sure what to look for. My main theory now is the pipe that lets the water get into the block fromt he water pump is possibly blocked. Should I run a hose to that pipe directly and see if water come out somewhere? Any help would be appreciated.
-Justin
-Justin
