yamahardro1
Thread starter- Joined
- Jul 28, 2010
- 7
hey guys,
got a 87 merc 3.0 recently and have run through itafter it satr for 2 years. new starter, plug, rotor, condenser, points, fuel pump, oil and filter change, fuel water seperator.
to get to engine to start, has to be at 1/4 throttle, once running it will race up to ~3k rpm's and as soon as i back it down it dies right out. start it back up at 1/4 throttle, seem ok again, throttle response is rather crappy, back it down slowly from 1/4 and it cuts right out.
i took the carburetor off and cleaned thoroughly, float was not stuck, plunger for accel. pump intact and working properly. both jets are spraying.. re-installed carb with all new gaskets and check, still having the same problems.
please help, thanks!
